Arch Linux - KDE4.14, XNVIEWMP 0.69 x64
1) From the file list rename a folder (F2) or create a folder.
2) Right Click folder and New Folder, Delete, Rename, Copy, Cut, Paste, Copy to... and Move to... are all greyed out.
Also just discovered if you rename a folder browse away from it and then try and go back to it (i.e. click on the newly rename folder in the file list) it won't show the contents of the folder but instead keeps displaying the contents of the previous folder. Also the in the dropdown box of the filelist toolbar it doesn't change when you go to a newly created/renamed folder staying instead with path of the previously selected OK folder.
(Linux) After rename/create from file list no actions avail.
mykurtaccount
