Can I switch between browser and full screen only?
Start from file now goto fullscreen. Then, Enter has no effect and double click open viewer.
Is possible that Enter or double click goto directly to browser with directory tree?
Otherwise, is there a way to disable viewer?
MS Win 7/64, XNViewMP 0.69/64
Switch to browser and fullscreen only
m.Th.
Re: Switch to browser and fullscreen only
Use F11
Also if you want, you can play with the keyboard customization but I wouldn't advise it in this case.
m. Th.
cicciobello
I always use F11.m.Th. wrote:Use F11
But I do *not* want Viewer, just only Browser and fullscreen. Is this possible?
canislupus
under “Settings – Interface – Switching mode” you can choose “Browser <> Fullscreen | Viewer <> Fullscreen” for e.g. for middle click or as you want.
cicciobello
I have already set this options.canislupus wrote:under “Settings – Interface – Switching mode” you can choose “Browser <> Fullscreen | Viewer <> Fullscreen” for e.g. for middle click or as you want.
Simply, I want disable Viewer.
Best of all (for my use), is this Switching mode: "Browser <> Fullscreen".
Cybertect
Me too. I´d love that....
