I've two smaller wishes for next releases on XnView.
1. I'd like to see the files date in the status bar in both views (browser and image). Even better it would be if one could customize the infos displayed there .
2. It looks like the cached informations grow and grow with time. Is there any way to limit how much directories/images are cached, resp. how much space the cache can take up? If not, an option to limit the cache to x MB or y directories (delete oldest if limit reached) would be great. Doing that manually can be annoying soon I guess.
Jürgen
Date in status bar, limiting cache
Dreamer
Re: date in status bar, limiting cache
Please check (and support) this suggestion - REQ: Limit Cache Option.jherz wrote:2. It looks like the cached informations grow and grow with time. Is there any way to limit how much directories/images are cached, resp. how much space the cache can take up? If not, an option to limit the cache to x MB or y directories (delete oldest if limit reached) would be great. Doing that manually can be annoying soon I guess.
Please don't reply to this (2nd) request here, Thanks.
