Version 2.24
When scanning the logical drive often occurs closing the program with an error.
When scanning probably come across files that the program can not correctly process.
I send you the archive with the files on which the program is closed permanently fail: https://yadi.sk/d/wPjk-iqvbzyyB
Because of this error I can not fully scan the entire logical drive and get a search result images.
Additionally: There is a need to search for the signature of image formats files in all search modes.
When I run a search on logical drive and the indicated in the field "format" -> "all graphics files" be searched by file extension, although in the options deselect the option "Recognize only by extension". For example ACDSEE 5.0 is always looking for the signature of the file, not the file extension.
Frequent crash while scanner file system
Papateodoro
Re: Frequent crash while scanner file system
you have a crash when you browse this folder?
Papateodoro
The Crashed when programma scan disk in mode "search".xnview wrote:you have a crash when you browse this folder?
I try again - result:
Folder "4IXR1P1Z" in archive:
Browse - Ok;
Scan in mode "Search", turn field "format" to "all graphics format" - CRASH.
All search options is Off- Ok.
Folder "8NA3STS3" in archive:
Browse - CRASH;
All search options is Off - CRASH.
This problem occurs very frequently. Especially on the system drives.
ok, right, in search there is a crash...
Papateodoro
My system: Windows 7 Ultimate 64-bit
After installation 2.25 verion previous problem solved.
Program in search does not crash, but when create sketches error occurred "runtime error 203 at 00003409".
After click OK again there was an error after you click OK again there was an error 216 at 00007D81.
The program hangs. However, XnviewMP 0.7 in the same situation is not an error - good work.
Does the program "file-log" ?
