I can't open files by dragging and dropping into XnViewMP browser. Why?
It takes one middle click to go into fullscreen viewer but it takes two middle clicks to exit fullscreen. I want to set it to only one.
There are two mouse wheel options in Settings > Interface > Mouse but only the first one works.
If you have 'Floating views' and 'Show toolbar' both enabled in View > Fullscreen the floating view will block the toolbar when you try to mouseover it. I tried to move the toolbar to the left and bottom side but if you change anything in Settings it puts the toolbar back at the top.
Can't drag and drop files onto browser and other issues
CreativeWorld
Re: Can't drop and drop files onto browser and other issues
do you drag&drop the file on tabbar?CreativeWorld wrote:I can't open files by dragging and dropping into XnViewMP browser. Why?
i have no problem hereIt takes one middle click to go into fullscreen viewer but it takes two middle clicks to exit fullscreen. I want to set it to only one.
The second is with CTRLThere are two mouse wheel options in Settings > Interface > Mouse but only the first one works.
could you post a screenshot?If you have 'Floating views' and 'Show toolbar' both enabled in View > Fullscreen the floating view will block the toolbar when you try to mouseover it. I tried to move the toolbar to the left and bottom side but if you change anything in Settings it puts the toolbar back at the top.
CreativeWorld
Oh ok this works. I was trying to drag the file into the browser and preview window. I prefer to use the browser instead of a tab.xnview wrote:do you drag&drop the file on tabbar?
CreativeWorld wrote:It takes one middle click to go into fullscreen viewer but it takes two middle clicks to exit fullscreen. I want to set it to only one.
I turned on my computer today and this problem went away. Strange.xnview wrote:i have no problem here
Ahh. It doesn't say "+ CTRL" next to mouse wheel so I got confused.There are two mouse wheel options in Settings > Interface > Mouse but only the first one works.
Herecould you post a screenshot?
This happens if I draw a selection box in the picture, then exit fullscreen, then go back to fullscreen. Now the toolbar and floating bar is messed up. Restarting XnView fixes this. Also yesterday I was able to move the toolbar to the left and bottom of the screen but today it is not movable anymore. That's weird.
