[v2.24] Can't view picture when inside an archive
iycgtptyarvg
I have rar and 7z archives with pictures in them. When I press <enter> or double click an archive, XnView goes into the archive and shows thumbnails for the pictures.
But, when I now press <enter> or double click on a picture, it doesn't show me the picture. Also, pressing <F11> to show the picture full screen doesn't work.
The only thing that does work is choosing 'Open' in the right click popup menu.
Please fix.
Please fix.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into
(")_(") your signature to help him gain world domination.
Re: [v2.24] Can't view picture when inside an archive
you had not that with previous version?
iycgtptyarvg
I don't know. I never tried. I used to always unpack archives and then view them (with FSViewer). But, that viewer doesn't support archives so I came to XnView.
That's when I discovered it didn't work.
Do you want me to try older versions? Where can I find older versions?
(\__/)
Do you have unrar & unace in Addon folder?
iycgtptyarvg
I have this in the AddOn directory:
Hmmm... I see the 7z.dll is from 2006?!? Surely that should be newer. Maybe that's the problem?
7z.dll 57,344 bytes 2006-08-10 18:05:10 MD5:9a46cb71cd1198600aab5a3112841349
pngout.exe 38,912 bytes 2012-01-17 10:34:58 MD5:05c673de53b2d220a4c9cb289d716f2c
PNGout.lng 2,728 bytes 2009-06-11 11:27:12 MD5:9bccb12af29453aa5add9b7166bd5bdb
PNgout.xnp 77,824 bytes 2007-12-19 17:31:00 MD5:0c616d92e866a3792971ac2f91273ba5
sqx20.dll 413,793 bytes 2006-04-20 19:19:28 MD5:4054733f94f54c5019978a9be4b8ba22
UNACEV2.DLL 77,312 bytes 2005-08-26 02:50:00 MD5:de02c4d04088b69e64ecc30a3d9e22e5
unrar.dll 219,224 bytes 2014-08-06 20:04:48 MD5:570e94acbc5e43e7a3c217148291be4c
Unzip32.dll 197,120 bytes 2014-08-08 16:05:16 MD5:12edd0dc270d711d4fa9f4beaeb20682(\__/)
could you send me a rar/7z archive to test?
iycgtptyarvg
Sure, I attached an example. Every archive fails for me. (the pics are really small because attachment have a ridiculous 1MB limit).
PS
I added my ini file too.
PS
(\__/)
iycgtptyarvg
I don't have Rar, I use 7z. The Rar files were from my work with classified design images, so I can't give them to you.
Do the 7z archives work for you?
(\__/)
ok, will be fixed
iycgtptyarvg
Great! Can you tell us what went wrong?
Edit:
Still not working in v2.25
Edit:
(\__/)
iycgtptyarvg
This has still not been fixed in v2.31.
Is there any news on this bug? Is it so much harder to fix than expected?
(\__/)
you have always this bug with 2.31???? zip?iycgtptyarvg wrote:This has still not been fixed in v2.31.
iycgtptyarvg
7-zip.
(\__/)
i have no problem to preview files in .7z archiveiycgtptyarvg wrote:7-zip.
