When Tabs are hidden (ie Viewer windows) how can we switch between files opened in Viewer, and how do we know how many files are being viewed?
note: it saves some space on a small screen when hiding the tabs.
Its easy to switch back to Browser with the toolbar button, but I can't get back to the viewed files after that.
It would be nice to have an alternative indication of Viewer windows opened, such as numbers |1|2|3|4| on the same level as the Menu bar (but that may be impossible to code?) - or on the status bar?
|1| would always default to Browser, unless you have |Browser button|1|2|3|4|
Could map SHIFT-TAB to switch between tabs and have a pop-up tab cycling window? I think that would be very easy UI.
Hide tabs, how to see what files opened in Viewer?
orbspider
m.Th.
Re: Hide tabs, how to see what files opened in Viewer?
Did you tried Ctrl+Tab?
m. Th.
orbspider
Ctrl-Tab does nothing!
Build Debian http://dquinton.github.io/debian-install/
HanVroon
Or perhaps have the Window menu item back from Classic that is missing in MP?
If yes, than also the Tile menu options, together with a list of opened windows?
Regards,
Han
Regards,
Han
