In XnView 2:24, in Windows, when I want to compress a group of images with the plug-in Zip-Pack (1.0), it appears a window saying:
Problem
ZIP32.dll can not be found in AddOn folder!
Also I can´t view the images in a zip file in XnView 2.24.
But Zip32.dll and Unzip32.dll are actually in the AddOn folder.
This problem only appears in XnView 2.24, but not in previous versions. For example, in XnView 2.22 it Works fine, and i can compress and view the images of a zip file.
Thanks in advance.
Problem with Zip32.dll and Unzip32.dll in XnView 2.24
johanmark
Re: Problem with Zip32.dll and Unzip32.dll in XnView 2.24
yes it will be fixed...
