zoom problem in v0.69
ivoat16
I have tried XnView MP 0.69 x64 - the .exe and portable versions both, and there is a problem with the zoom - after a few starts of the program, when I zoom to fit a small image to the screen, and then close XnView MP, when I open other image it starts zoomed-in. This happens after a few starts of the program, not immediately after installing it, so I assume it is a cache problem. This happened with 0.68 too. I am using it under Windows 8.1 x64. I tried saving the program settings in .ini file and in the registry - no difference made. This problem appears after 1-2 days of use and I cannot reverse the settings back to 100% zoom at start of the viewer. So I have uninstalled MP and got back to XnView standard, where is no such problem. I only tried MP because it is 64 bit software. I hope you'll manage to fix this bug, as MP is a good 64 bit viewer. If you need more details, please e-mail me.
Re: zoom problem in v0.69
lock zoom is enabled?
