Dicom Image Tags
inspectaclueso
Dicom Image Tags
Post by inspectaclueso »
Dicom medical imaging files have embedded tags like most other files. The DICOM tags can be seen in the image properties however the tags are not available to overlay on the image when either viewing or converting.
Is this functionatlity something you would consider adding?
DICOM image viewers display serveral tags by default such as the patients name, part of the body they are looking at etc.
It would be great if XnView could do something similar either incorporated into the viewer or the ability to overlay the DICOM tags when converting so I can replicate what it would look like in a DICOM viewer such as MicroDicom.
Thanks
