File System Issues
Brother Gabriel-Marie
File System Issues
Post by Brother Gabriel-Marie »
Here are two problems, possibly related (MP 0.69 x64 on Windows 7 Pro x64):
1. I can't seem to cut and paste files.
2. If I drag files from the old XnView into MP (same drive letter) they always get copied instead of moved - even if I hold down shift whilst doing so. However, there is no problem moving files from MP to old XnView.
Re: File System Issues
Brother Gabriel-Marie wrote: 1. I can't seem to cut and paste files.
With menu entries?
ok known issue
With menu entries?
I tried to cut a jpeg and paste it. It seems to cut (using the keyboard, but also with the context menu), but paste is unavailable (context menu is grayed out, and the ctrl+v does nothing).
ok known issue
See Issue 520 for current status and details.
With menu entries?
I've tried and Paste is not greyed...
Pierre,
I can't get it to not work today. If I can, I'll get a better synopsis for you as well as a screenshot.
Thanks.
Could you please try out with XnView MP v0.84 and see whether the copy & paste problem still occurs, Brother Gabriel-Marie?
Helmut - you are making me think about all these things that were wrong two years ago...
Okay, so I am able to copy and paste just fine now!
Even drag and drop into and out of XnView seems to be all a-okay!
Thanks!
Brother Gabriel-Marie wrote:Helmut - you are making me think about all these things that were wrong two years ago...
Yes, sorry. I don't want to bother people but silently closing bug reports is not a good idea.
Brother Gabriel-Marie wrote:Okay, so I am able to copy and paste just fine now!
Thank you for trying and reporting back, Brother Gabriel-Marie! :)
:arrow: Closed
