Batch Resize
kubekj
Batch Resize
Post by kubekj »
Hello
When I batch resize or batch rename in XnViewMP the original order of files being processed is always reverted regardless how they are sorted before the command. Example - if source files are called 1.jpg, 2.jpg, 3.jpg after the batch operation the output files are always in oposite order: new1_3.jpg, new2_2.jpg, new3_1.jpg.
You can see it exactly on the attached pic. It is driving me crazy as it changes the order the pictures were taken.
Any hint how to change that ?
Re: Batch Resize
In input tab the files are sorting correctly?
kubekj
Re: Batch Resize
Post by kubekj »
yes the same way as on in the folder on the pic
Re: Batch Resize
kubekj wrote:yes the same way as on in the folder on the pic
it works correctly for me, could you post a screenshot of files tab?
