EXIF is lost after removing red eye
YuriPanfilov
Post by YuriPanfilov »
EXIF is lost after applying "remove red eye" and saving the file! It occurs in all versions of XnView. I don't wanna use other software to remove red eye. Please correct it!
YuriPanfilov
Re: EXIF is lost after removing red eye
Hi.
Some images don't lose EXIF after "Remove red eye".
I've put image which loses EXIF on http://download1783.mediafire.com/116k0 ... CN2574.rar
(Image is in Winrar archive "DSCN2574.rar". Size is 1.83 MB.)
And I found solution:
1. Copying EXIF data to XMP.
2. Deleting the XMP data.
In result the image will not lose EXIF after "Remove red eye"!
I use software "Exif Pilot". It lets to edit all EXIF tags. And I hope that the XnView will be fixed.
Yuri.
