XNCONVERT Version 1.66 - x64 Broken
luis
Hi
After installing XNCONVERT Version 1.66 - x64 on iMac 2,5 GHz Intel Core i5 Running Yosemite I encountered a couple of problems :
Drag and drop files not longer working.
Meanwhile import from folder works but doesn't produce any result.
Previous version was working just fine.
Hopefully you can help with a solution.
Thanks
L
Thanks
L
Re: XNCONVERT Version 1.66 - x64 Broken
If you use this one http://download.xnview.com/old_versions ... ac-x64.tgz all works??
luis
Yes this works.
and with 1.66, you can't add files??luis wrote:Yes this works.
luis
Its written in the first message.
Thanks again.
Luis
Thanks again.
Luis
i contact you by pm
Koruru
I've got the same problem here.
Mac 27'' Mid 2011, 2.7 GhZ Intel Core i5, 16 GB RAM
OS X Yosemite 10.10
OS X Yosemite 10.10
Please download the version again from my website
crazycordy
sorry to hijack the thread, but i've been having the drag & drop issue since updating to 1.66, and I use it almost daily, and while having to manually select the files isn't a huge deal, it's definitely making my work slow down. I tried downloading XNviewMP and using that batch conversion and I have the same issue. If it's helpful, I am running Yosemite on an iMac 2.5 GHz Intel Core i5
yes, there is a bug between QT API & Yosemitecrazycordy wrote:sorry to hijack the thread, but i've been having the drag & drop issue since updating to 1.66, and I use it almost daily, and while having to manually select the files isn't a huge deal, it's definitely making my work slow down. I tried downloading XNviewMP and using that batch conversion and I have the same issue. If it's helpful, I am running Yosemite on an iMac 2.5 GHz Intel Core i5
You can download previous version 1.65
iFab
Hi, I confirm the bug of drag and drop with XNC 1.66 and Yosemite (latest version), but it only happens if you do it in the program window, while it works if you drag the files onto the dock icon.
In this regard, I ask the developers, any news about it?
i wait that this bug is fixed in QtiFab wrote:Hi, I confirm the bug of drag and drop with XNC 1.66 and Yosemite (latest version), but it only happens if you do it in the program window, while it works if you drag the files onto the dock icon.
iFab
Sorry I'm a graphic designer and not a programmer, for "Qt" you mean Quicktime and for "wait " you mean a solution from Apple? Ok, then I'll continue to do the drag & drop on to the dock icon.
sorryiFab wrote:Sorry I'm a graphic designer and not a programmer, for "Qt" you mean Quicktime and for "wait " you mean a solution from Apple? Ok, then I'll continue to do the drag & drop on to the dock icon.
iFab
Thanks for pointing this out, but it doesn't change much for me. My programming is stopped since " Hello World " on the Commodore 64.
