Is there a command line switch for NConvert?
such as here http://newsgroup.xnview.com/viewtopic.php?t=14476
also this question here http://newsgroup.xnview.com/viewtopic.php?t=19081
skip owerwrite if exist
Re: skip owerwrite if exist
by default, if file exists, NConvert rename the output file
Zurdo
Hi. I'm also looking for this command.
I have a folder with many pictures, which I convert to a lower resolution and copy to my mobile. What I'd like to do is to only convert the files that have not been convertedf before.
An nconvert switch like xnconvert's "skip if destination already exists" would be great!
Thanks,
Zurdo.
Thanks,
Zurdo.
Mixer
- Banned
Hi Zurdo. On Windows you could use batch file similar to this.
@echo off
for %%i in ("C:\Source Directory\*") do (
if not exist "F:\Destination Directory\%%~nxi" start /wait nconvert.exe -o "F:\Destination Directory\%%~nxi" -resize longest 199 "%%i"
pause-
Zurdo
Excellent solution Mixer!!! Thanks a lot! Works great!
Mixer
- Banned
You're welcome. It works only while your files have none of characters % # $ in their names.
