That's the first time I ask for something here, so I'll try to be as precise as possible :
I don't know wether it's a bug or if it's normal (you can move my post according to that if I'm wrong) but when I'm trying to open TIFF pictures (multipages) I just get a black screen (I mean all the picture is in black but not my screen actually).
The point is when I open them with windows preview/Irfanview it works normally.
Another crucial (maybe) point is when I rotate these pictures with win preview, I can then open them with XnView... but their size is increased three times than before rotating
I have the same problem with XnConvert if that can help!
Thanks for any piece of answer (or whole!)
N2A
PS: Have a notebook win 7 32bits
black screen with large TIFF pictures
Re: black screen with large TIFF pictures
The ideal would be if you could upload a sample file, but as the current forum attachment limit is 1MiB that could be difficult; do you have or can you create a small enough example file that shows the problem, or could you upload a file to a file hosting service and provide a link?N2A wrote:I don't know whether it's a bug or if it's normal ... but when I'm trying to open TIFF pictures (multipages) I just get a black screen (I mean all the picture is in black but not my screen actually).
Do you know which program the files were created in, and whether the same issue applies to single-page files, which would be rather smaller? If opening the file in another program and then saving it overcomes the problem, that suggests a quirk in the original program used to create the files that isn't recognised in XnView software.
If the pixel dimensions of the images are very large, the limit to the amount of ram that can be addressed in a 32-bit system could be reached, although I'm not sure if other software could handle memory differently.
N2A
Here is one of the problematic file : http://ovh.to/YsrPud5 (not even so large that one) I've tried on a 16gb RAM Win 7 64b as well but I got the same result.
The files are created in Panoptiq (it scans microscopic blades). I don't know why the pictures are multipage ones but anyway I can't obtain single-page pictures with that software (settings are really limited).
The picture is not completely black : a small mosaic of some zones of the picture appears on the left side
Thank you for taking my problem into considerations
The file you uploaded is a tiled TIFF with JPG compression, the first image has quite large pixel dimensions but the following images are smaller.
There has evidently been a problem with similar files in the past as in the following post:
http://newsgroup.xnview.com/viewtopic.php?f=35&t=26063
It would appear that the issue hasn't been resolved yet, which seems surprising if other readily available viewers can open the file...
- Forum Librarian
I can confirm cday's observation that Panoptiq seems to produce JPEG-encoded pyramidal (tiled multi-resolution) TIFFs.
Perhaps the following information will be of use to Pierre:
AWare Systems (TIFF File Format FAQ » [url=http://www.awaresystems.be/imaging/tiff/faq.html#q9]So what are the defined tags exactly? Where can I find information on any specific tag?[/url]) wrote:The number one source on this is the TIFF specification. Note that this doesn't include any private tags or custom tags, of course. Also, please note that the JPEG-in-TIFF section is overridden by TechNote2, absorbed in TIFF Specification Supplement 2
Related topics:RemoteSensing.org (LibTIFF » [url=http://www.remotesensing.org/libtiff/document.html]TIFF documentation[/url]) wrote:Draft TIFF Technical Note #2 covers problems with the TIFF 6.0 design for embedding JPEG-compressed data in TIFF, and describes an alternative.
- I can't view some tiff files in XnView 1.96.2
- "TIFF (Tiled)" - what does it mean? (already mentioned by cday)
Page #1 (resolution X * Y) wrote:Code: Select all
ImageWidth (1 Short): 7098 ImageLength (1 Short): 6441 BitsPerSample (3 Short): 8, 8, 8 Compression (1 Short): JPEG Technote #2 Photometric (1 Short): RGB ImageDescription (34 ASCII): Panoptiq|AppMag = 2|MPP = 2.87976 SamplesPerPixel (1 Short): 3 PlanarConfig (1 Short): Contig TileWidth (1 Short): 512 TileLength (1 Short): 512 TileOffsets (182 Long): 16, 9273, 18530, 27787, 37044, 50432, 71650,... TileByteCounts (182 Long): 9257, 9257, 9257, 9257, 13388, 21218, 29309,... JpegTables (289 Undefined): YCbCrSubsampling (2 Short): 2, 2
Page #2 (resolution X/2 * Y/2) wrote:Code: Select all
ImageWidth (1 Short): 3549 ImageLength (1 Short): 3220 BitsPerSample (3 Short): 8, 8, 8 Compression (1 Short): JPEG Technote #2 Photometric (1 Short): RGB ImageDescription (34 ASCII): Panoptiq|AppMag = 2|MPP = 2.87976 SamplesPerPixel (1 Short): 3 PlanarConfig (1 Short): Contig TileWidth (1 Short): 512 TileLength (1 Short): 512 TileOffsets (49 Long): 10561701, 10570958, 10585235, 10612169,... TileByteCounts (49 Long): 9257, 14277, 26934, 50199, 75815, 55051,... JpegTables (289 Undefined): YCbCrSubsampling (2 Short): 2, 2
Page #3 (resolution X/4 * Y/4) wrote:Code: Select all
ImageWidth (1 Short): 1774 ImageLength (1 Short): 1610 BitsPerSample (3 Short): 8, 8, 8 Compression (1 Short): JPEG Technote #2 Photometric (1 Short): RGB ImageDescription (34 ASCII): Panoptiq|AppMag = 2|MPP = 2.87976 SamplesPerPixel (1 Short): 3 PlanarConfig (1 Short): Contig TileWidth (1 Short): 512 TileLength (1 Short): 512 TileOffsets (16 Long): 13523189, 13541216, 13612385, 13697340,... TileByteCounts (16 Long): 18027, 71169, 84955, 12588, 75450, 130256,... JpegTables (289 Undefined): YCbCrSubsampling (2 Short): 2, 2
Page #4 (resolution X/8 * Y/8) wrote:Code: Select all
ImageWidth (1 Short): 887 ImageLength (1 Short): 805 BitsPerSample (3 Short): 8, 8, 8 Compression (1 Short): JPEG Technote #2 Photometric (1 Short): RGB ImageDescription (34 ASCII): Panoptiq|AppMag = 2|MPP = 2.87976 SamplesPerPixel (1 Short): 3 PlanarConfig (1 Short): Contig TileWidth (1 Short): 512 TileLength (1 Short): 512 TileOffsets (4 Long): 14369253, 14450092, 14510825, 14569767 TileByteCounts (4 Long): 80839, 60733, 58942, 29614 JpegTables (289 Undefined): YCbCrSubsampling (2 Short): 2, 2
N2A
Sorry I was offline this week end!
thank you for your answers even if they can't solve my problem for the moment, I hadn't catched that the other posts were about the same problem sorry for that.
Do you know why rotating the pictures allow me to open them with XnView? Is the rotation process (with win preview) changing completely my files?
Thanks
Thanks
- Forum Librarian
That's alright. I'm just trying to “connect the dots”N2A wrote:I hadn't catched that the other posts were about the same problem sorry for that.
Yes, I think so. Windows Photo Viewer seems to extract the “page” with the highest resolution and re-saves it either uncompressed or with a more common but less effective compression method.N2A wrote:Do you know why rotating the pictures allow me to open them with XnView? Is the rotation process (with win preview) changing completely my files?
wojciech.s
I would like to refresh this topic. I've encountered similar problems with TIFFs which are aerial photos. They are opened by XnView MP 0.98.3 as black. Windows 10 builtin Photos app opens those files without problem. AFAIK those are tiled TIFFs.
I'm attaching info from tiffinfo. I can't share those files publicly as they are licensed, but I can send one of those via PM for testing only.
TIFF Directory at offset 0x4f9ecf0 (83487984)
Subfile Type: (0 = 0x0)
Image Width: 17272 Image Length: 16955
Tile Width: 128 Tile Length: 128
Resolution: 714.286, 714.286 pixels/cm
Bits/Sample: 8
Compression Scheme: JPEG
Photometric Interpretation: YCbCr
YCbCr Subsampling: 2, 2
Samples/Pixel: 3
Planar Configuration: single image plane
Reference Black/White:
0: 0 255
1: 128 255
2: 128 255
JPEG Tables: (1722 bytes)
TIFF Directory at offset 0x64920e0 (105455840)
Subfile Type: reduced-resolution image (1 = 0x1)
Image Width: 8636 Image Length: 8477
Resolution: 357.143, 357.143 pixels/cm
Bits/Sample: 8
Samples/Pixel: 3
0: 0 255
1: 128 255
2: 128 255
Tag 33919: 2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
JPEG Tables: (574 bytes)
TIFF Directory at offset 0x6a48cf0 (111447280)
Image Width: 4318 Image Length: 4238
Resolution: 178.571, 178.571 pixels/cm
Bits/Sample: 8
Samples/Pixel: 3
0: 0 255
1: 128 255
2: 128 255
TIFF Directory at offset 0x6bc37b0 (112998320)
Image Width: 2159 Image Length: 2119
Resolution: 89.2857, 89.2857 pixels/cm
Bits/Sample: 8
Samples/Pixel: 3
0: 0 255
1: 128 255
2: 128 255
TIFF Directory at offset 0x6c1fd10 (113376528)
Image Width: 1079 Image Length: 1059
Resolution: 44.6429, 44.6429 pixels/cm
Bits/Sample: 8
Samples/Pixel: 3
0: 0 255
1: 128 255
2: 128 255
TIFF Directory at offset 0x6c37684 (113473156)
Image Width: 539 Image Length: 529
Resolution: 22.3214, 22.3214 pixels/cm
Bits/Sample: 8
Samples/Pixel: 3
0: 0 255
1: 128 255
2: 128 255
TIFF Directory at offset 0x6c3e1c4 (113500612)
Image Width: 269 Image Length: 264
Resolution: 11.1359, 11.1235 pixels/cm
Bits/Sample: 8
Samples/Pixel: 3
0: 0 255
1: 128 255
2: 128 255
TIFF Directory at offset 0x6c405cc (113509836)
Image Width: 134 Image Length: 132
Resolution: 5.54324, 5.56174 pixels/cm
Bits/Sample: 8
Samples/Pixel: 3
0: 0 255
1: 128 255
2: 128 255
TIFF Directory at offset 0x6c41380 (113513344)
Image Width: 67 Image Length: 66
Resolution: 2.77085, 2.78087 pixels/cm
Bits/Sample: 8
Samples/Pixel: 3
0: 0 255
1: 128 255
2: 128 255
TIFF Directory at offset 0x6c41b18 (113515288)
Image Width: 33 Image Length: 33
Resolution: 1.36482, 1.39024 pixels/cm
Bits/Sample: 8
Samples/Pixel: 3
0: 0 255
1: 128 255
2: 128 255
TIFF Directory at offset 0x6c42068 (113516648)
Image Width: 16 Image Length: 16
Resolution: 0.661682, 0.674082 pixels/cm
Bits/Sample: 8
Samples/Pixel: 3
0: 0 255
1: 128 255
2: 128 255
TIFFReadDirectory: Warning, 1_1201.tif: unknown field with tag 33919 (0x847f) encountered.
