I have a tif file that I'm trying to convert to a pdf file. When using nconvert, the -binary floyd option is causing it to crash and return a 255 error code. I included the full command line in case some other parameter might be having an effect. If I remove the -binary floyd option, it works. I can open the tif in paint so it seems to be a valid tif file. I can also convert it in xnView using the Floyd option and it works there. So I don't know what the problem is with nConvert.
The -binary nodither option works and seems to do the same thing. I know nothing of all this graphic stuff and its terminology. I have no clue what the -binary option does. If nodither does the same thing as Floyd, I could just use that. Can anyone provide any guidance?
The resulting pdf file is run through somewhat of an OCR process that pulls data out based on the x/y axis location. The x/y axis locations are drawn and recorded by a person using a viewer app. Maybe the -binary Floyd option cleans up the image to make it work better for our process?
Thanks,
Kevin
C:\Files\Tools\nconvert.exe -out pdf -o "C:\Temp\DCSTest.pdf" -c 3 -xall -binary floyd -dpi 200 -multi -v "C:\Temp\DCSTest.tif"
nConvert crashes using -binary floyd
Re: nConvert crashes using -binary floyd
i have no crash with floyd setting, please could you send me your tif file?
kevinv
I'll have to see if we can send it out. They are customer proprietary images and I need to check with upper management.
kevinv
I can send you the TIF. Do you have an email address I can use? I don't want to attach it for anyone to see.
- Forum Librarian
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=11#p11]Welcome![/url]) wrote:Also, you can mail me directly via.
