change inserted text not possible
mgk
Post by mgk »
When I insert a text in a foto, I am not able to change it / delete it afterwards. Is there any trick to do this ? :?:
( xnview Version : v2.25 de )
Re: change inserted text not possible
mgk wrote:When I insert a text in a foto, I am not able to change it / delete it afterwards. Is there any trick to do this ? :?:
Text inserted using XnView software becomes part of the image: layers are not supported, so the text is not placed on a separate text layer which would enable it to be edited later. If you require a freeware program that supports layers for future work, you might look at Paint.NET.
If you need to try to restore images created using XnView software, you might find this thread useful:
http://newsgroup.xnview.com/viewtopic.php?p=121597
mgk
Post by mgk »
cday : thanks for the infos
