Change request: Batch rename - use part of original filename
violine
Post by violine »
The subject says it all. As already discussed in this forum it would be a very helpful option if someone could use parts of the original filename when batch renaming files.
The current version 2.25 only supports the whole original filename with the <Filename> or <Filename With Ext> tag.
My suggestion is to extend it with []
Examples:
  • <Filename[1]> is I
    <Filename[2]> is M
    <Filename[1-4]> is IMGP
    <Filename[5-8]> is 1234
    <Filename[1-23]> is IMGP1234
Additional the same operations on the extension could be useful:
    <Ext[2-4]> is jpg
Once this is implemented it could also be used for converting to UPPER- or lower case
  • <FILENAME> converts to uppercase and
    <filename> converts to lowercase
    <Filename> doesn´t change the case
Same with other 2 options.
Please tell me what you think about this.
It would be great if XnView could to this job. So there would no more need to change to another program just for renaming files.
Philrou
Re: Change request: Batch rename - use part of original file
Post by Philrou »
Some news about this good idea ? :?:
Merci
violine
Post by violine »
I'm still missing this feature in the current version XnView Standard 2.32.
If you also would like this to be implemented, please let the author know!
violine wrote:I'm still missing this feature in the current version XnView Standard 2.32.
you have it in lastest version
