Black color of Folder's icon (if ≦ 256 colors) invisible
senchiyo
Post by senchiyo »
In Folder pane, if a folder's icon is 256 colors and below, its black color will be invisible.
I have found this problem since 2 years ago the first time I used XnView MP.
Re: Black color of Folder's icon (if ≦ 256 colors) invisible
could you post a screenshot?
senchiyo
Post by senchiyo »
For example,
The upper is shown in XnView MP's Folder pane, the lower is shown in Windows Explorer's Folder pane.
Only three colors are used in the icon: Black, White & Red.
you have associated an icon with folder in windows explorer?
senchiyo
Post by senchiyo »
xnview wrote:you have associated an icon with folder in windows explorer?
No. I customized a folder's icon by Windows built-in function. Ref. http://www.cnet.com/how-to/how-to-custo ... windows-7/
senchiyo
Post by senchiyo »
This problem remains alive in 0.76. :?
