hi all,
i got some interesting phenomen here:
[ ] go to next image when deleting current.
if i delete a file with DEL in the viewer, the file is deleted, but nothing happens with the file which is shown. if i press DEL again (because i think, that nothing happened) xnview says, that the file cannot be deleted. (which is because i deleted it already, i think)
so this seems not to be a bug, but is very confusing (me)
[x] go to next image when deleting current.
the previous file is displayed after i deleted the current picture in the viewer.
this seems to be a bug, but maybe i didnt find the other right switch on the options?
anyboy any suggestions?
loth
Deleting files moves to the last file, not the next.
Re: Deleting files moves to the last file, not the next.
Ok, only when you are in fullscreen, right?loth _ wrote:hi all,
loth
yes.xnview wrote: Ok, only when you are in fullscreen, right?
loth
