0.70 file listing not showing all files
bitz4
Post by bitz4 »
I've selected all other files to be visible and show as thumbnail and it's not showing.
MP 0.90 x64, Win 7 64-bit
Re: 0.70 file listing not showing all files
and you have files in this folder?? do you use Filter>Custom?
bitz4
Post by bitz4 »
Above in win explorer is a file called 0.
If there were pictures and folders in it, 0 would be missing, the rest would show up.
Actually, after looking at the filter icon, it's set to All. If I set it to Custom it shows the 0 file.
A bit confusing as I normally think All would mean all files.
OK, so it works but only in Custom mode. What does Filter>All do, anyway?
Custom mode use your custom filter
bitz4 wrote: OK, so it works but only in Custom mode. What does Filter>All do, anyway?
show all files
