BPG Image format
Gravitator
BPG Image format
Post by Gravitator »
Re: BPG Image format
do you have some bpg files?
Gravitator
xnview wrote:do you have some bpg files?
No.
I want to get through your converter (prefer to use ready-made products).
Hacker
Post by Hacker »
I wholeheartedly support the wish for XnView to implement BPG support (at least for decoding). I do not mean XnConvert specifically, though, I'd rather be using XnView to view them; I can create them on my own. The sources are available at the link posted above or one can use the libbpg library.
omniplex
Post by omniplex »
Gravitator wrote:Привет!
http://forum.doom9.org/showthread.php?t=167592
Apparently continued in t=171505, also mentioning XnView :wink: The example images are shown with Bellard's JavaScript, so you should be able to find links for the BPG sources in the HTML source (untested).
  • XnView bug tracker: 0000552 (BPG format)
captaincavern
Post by captaincavern »
For viewing in XnView there is a compiled susie plugin here: https://github.com/256bai/ifbpg
heimaki
Post by heimaki »
captaincavern wrote:For viewing in XnView there is a compiled susie plugin here: https://github.com/256bai/ifbpg
how is this supposed to work?
  1. Download susie.zip and (the latest version of) ifBPG-*.zip.
  2. Extract the contents of both archives to the Plugins subdirectory of your XnView installation.
  3. Restart XnView.
Hacker
Post by Hacker »
xnview,
Could the console window perhaps be suppressed / hidden? It looks really bad, covering the current image while the BPG image is being loaded.
Thanks!
Roman
Hacker wrote:xnview,
i wait the final version of library from bpg
JOZIKus
Post by JOZIKus »
Don't! It's a new and radical format with a lot to improve every month and every year. There will be periodic updates so waiting for the final version is unwise. I'd recommend to just upgrade to full newest version with both read and write support.
Also, I think WebP should be periodically updated too. Ability to set advanced parameters would be great too ;-) I know there are so many parameters, that You won't bother to implement every one of 'em, but what about an "input box" to write Your own advanced parameters for the encoder? That would be awesome! ;)
foxyshadis
Post by foxyshadis »
  3. Restart XnView.
We'll need a 64-bit build once 0.75 proper comes out, unless this isn't going to be supported on 64-bit.
heimaki
Post by heimaki »
