Option under Settings>Browser to disable thumbnails
nim
Post by nim »
When opening the browser in my Screenshots folder I'm dealing with a folder of hundreds of 4+ MB PNGs.
Scrolling the browser in this folder is practically impossible and I have to use Pg Up/Pg Dn and even that is very cumbersome.
I see you're focusing on the XnViewMP now but would it be easy to add an option in Settings>Browser to disable thumbnails? (Especially in Details view)
Will try/buy MP out! Cheers!
Re: Option under Settings>Browser to disable thumbnails
If you disable the cache??
nim
Post by nim »
it was already disabled. Fairly sure I haven't missed an option. :-)
Cheers
