Replacement for Windows Photo Viewer
devilmayqq
Post by devilmayqq »
As the title states, I recently have been looking for replacements for the default photo viewer and stumbled upon XnView. I'm not looking to use XnView as a photo editor, I have PS for that. Windows stopped supporting .gifs after XP using the default photo viewer that comes with the computer, and I'm looking for a modern replacement for that. A photoviewer that is very similar to it, but with gif support as well as regular image support (.png, .jpg, etc.).
Features I'm mainly looking for:
Zoom with mouse (XnView has this, most other programs didn't)
Moving to the previous or the next image with arrow keys by the current order of files ?
[i.e. InfraView didn't go off window's setting, but rather it's own]
Is it possible to use XnView like so? Are there certain settings I need to apply?
Re: Replacement for Windows Photo Viewer
you can use XnView as photo viewer without to use the browser
devilmayqq wrote:Features I'm mainly looking for:
Is this Tools > Options... setting what you are looking for?
Not sure about the current order of files, but you can test that...
devilmayqq
cday wrote: Is this Tools > Options... setting what you are looking for?
Yes, this is what I was looking for! I did not notice the next file part, I should be more wary next time, ahah.
Order seems to be by alphanumeric, don't see any way to change that. The files also don't loop back to the beginning or the end. Oh well.
devilmayqq wrote:The files also don't loop back to the beginning or the end. Oh well.
Is this the setting you need?
I'm not sure whether the alphanumeric display order can be changed, someone else may know :?:
cday wrote:I'm not sure whether the alphanumeric display order can be changed, someone else may know :?:
There's Name and Name (numeric) in View » Sort By.
In addition to that, you can change the behavior by editing xnview.ini:
XnView Wiki (UI-less Settings » [url=http://www.xnview.com/wiki/index.php/UI-less_Settings#Browser]Browser[/url]) wrote:
OldSortMethod
  • When disabled, XnView will use the same sort order as Explorer on Windows XP and later: File names are sorted based on numerical value (3 < 22 < 111).
    When enabled, XnView will use the same sort order as Explorer on Windows 2000 and earlier: File names are sorted literally (111 < 22 < 3).
    Value: Boolean (1/0), disabled by default
    Added in v2.25
Related topic: XN 2.23 - "View Thumbnails Panel" changed order of files
