0.71 Certain png + reduce noise = bad quality
DVDRip
Post by DVDRip »
comic from http://adbrvl.co/1GMhnsy (same link with 0.71 Wrong exe icon) is certain png
Re: 0.71 Certain png + reduce noise = bad quality
DVDRip wrote:comic from http://adbrvl.co/1GMhnsy (same link with 0.71 Wrong exe icon) is certain png
which png file?
xnview wrote:which png file?
PNG with .jpg extension
The color depth has to be increased to 24 bits for the filter to work.
yes reduce noise works only in 24bits
DVDRip
Post by DVDRip »
xnview wrote:yes reduce noise works only in 24bits
You wrong,most 8bit png + reduce noise = good quality.This png also works fine in XnView Classic.
