how to re-create the thumbnail stored in the exif data
xelag
Post by xelag »
I would like to now if it's possible with XnView MP under Linux to re-create the thumbnail stored in the exif data of a JPG file ?
As you can see in the screenshot below, XNView is showing the thumbnail stored in the exif data but it's not what the picture looks like.
I tried using the menu "View/REbuild thumbnail" but it does not do the trick.
thanks
Re: how to re-create the thumbnail stored in the exif data
Refresh thumbnails saved in XnViewMP's cache:
  • View » Rebuild thumbnails
Recreate thumbnails embedded in JPEG images:
  • Tools » Metadata » EXIF thumbnail - Rebuild
Welcome to the forum (-:
xelag
Post by xelag »
It works!
sorry I didn't see it by myself before !
thanks !
Phred
Post by Phred »
BTW, the rebuild operates on only those jpgs that have been selected, I find.
Tagging/ticking them doesn't lead to rebuilding thumbnails - the 'EXIF thumbnail - Rebuild' under Tools, Metadata remains greyed-out.
Note also that 'EXIF thumbnail - Rebuild' will be greyed-out when any non-jpg files are selected. Make sure you select only those files with EXIF data in them, most likely, jpgs.
NB All of this takes place in Browser mode.
Regards, PhredE
