Here's a feature that would be very useful to web designers: Produce multiple image files (with different dimensions) in a simple operation.
With modern webdesign, designers have a need to produce multiple sizes of images to accomodate different screen sizes and screen DPIs (e.g. HiDPI/Retina). It would be great if we could have multiple size profiles to produce from a single original image, in a simple repeatable process.
Thank you!
Resize to multiple files at once
- Forum Librarian
Re: Resize to multiple files at once
I support this request.
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=120736#p120736]Multiple outputs[/url]) wrote:
Evan
Thanks,
It seems this feature is only available through nconvert, not XnView(MP)? If so, then please consider this feature for some version in the future. Thanks.
- Forum Librarian
VarieDrop (freeware) isn't nearly as versatile as XnView, but it comes with an innovative UI.
See also: Batch processing via button
obelisk
I requested this too
My problem is how to put multiple destination UI in Batch convert
oops66
Hello, ... why not with different tags/categories and a single destination (into metadata for jpg, png, ...) ?xnview wrote:My problem is how to put multiple destination UI in Batch convert
obelisk
Set up script A, B, C in the current UIxnview wrote:My problem is how to put multiple destination UI in Batch convert
New UI window, run multiple script on selected images. Checkbox next to A, B, C.
