XnConvert crashes with Mac OX 10.10.1
Hammurabi
Post by Hammurabi »
XnConvert crashes everytime I add files to convert.
I have Mac OS X ver 10.10.1 (Yosemite)
I will appreciate if you would share all steps to fix this.
Regards,
Re: XnConvert crashes with Mac OX 10.10.1
which format of file?
Do you use the version from my website or apple store?
redspark
Post by redspark »
I'm having a similar issue. I'm using: XnConvert Version 1.66 - x64 (Nov 6 2014) - Libformat version 6.60
I think this is the one from the App store. I've installed both from the website first and then deleted it and then from the app store.
Almost every time I open a particular PNG file it blows up. But it doesn't do it every time for the one PNG file and not always for every PNG file. However, if I do get it to open without crashing, then it refuses to convert the file and throws errors in the log.
redspark wrote:I'm having a similar issue. I'm using: XnConvert Version 1.66 - x64 (Nov 6 2014) - Libformat version 6.60
Please contact me by mail
bogomaz
Post by bogomaz »
I have the same problem. OS 10.10.3. Bought in the Appstore. XnConvert crashes when downloading files (jpg, psd, tif).
bogomaz wrote:I have the same problem. OS 10.10.3. Bought in the Appstore. XnConvert crashes when downloading files (jpg, psd, tif).
could you try the version from my website?
bogomaz
Post by bogomaz »
I tried. Everything turned out. Thank you!
