XnView2.25|XnViewMP 0.72 64-bit-slowly opens each file jpg
makinero
Post by makinero »
XnView MP - slowly opens each file test (*.jpg)
Compare:
image viewer (Windows 7 64-bit | 4 Core CPU | 10 GB RAM) Superfast 0,5 - 1 second NOT FROZEN
IrfanView 4.38 32-bit - 5 second + temporary high CPU load + temporary frozen Windows
XnView MP - 3 .. 5 second + temp. frozen
XnView STANDARD - 1 second OPEN but a little slow(1-2 second) closing program
I installed XnView MP and very disappointed - very slow in opening images :(
How to improve the speed? Second in the opening are very, very, very important for me!
Re: XnView MP 0.72 64-bit - slowly opens each file *.jpg
how many files do you have in the folder?
makinero
Post by makinero »
xnview wrote:how many files do you have in the folder?
<=== it does not matter(!) This is a bad solution. I'm disappointed :(
Google search engine in a few seconds, can find a best solution! :D
It's just to understand, could you try XnView & XnViewMP in a folder with 2 pictures file and tell me if you have always same delay?
