Why does XnViewMP take up so much RAM?
borzov
Whenever I look through some heavy pictures the program gradually takes up more and more RAM. At some point pictures become pixelated until it says it can't open any more files. I have to exit and restart the program which is annoying. In ACDSee there was an option "keep previous image in memory/load next image in advance". And XnView seems to keep ALL the pictures in memory for some reason. Maybe there's some option in the settings that I've missed?
quapurna
Re: Why does XnViewMP take up so much RAM?
Halo.
Have you tried the following option-items:
Settings > View > Misc. > Cache > "Read one image ahead" and "Keep current image" ???
Thanks.
Thanks.
borzov
nope, didn't help
Do you open each image as a tab??
borzov
no, I scroll them
which format?borzov wrote:no, I scroll them
borzov
It takes me about 300 MB worth of jpg files (around 1 MB each) in 30 subfolders to reach 1.5 GB of RAM taken up by XnView at which point the "File can't be loaded" error pops up when I try to go from browsing to opening an image (and if I just scroll then the images turn up pixelated - I guess that means they cannot be decompressed).
I gotta say though this is much better then before I unchecked the "keep current image" as quapurna suggested. I guess it's just thumbnails now hanging in memory.
yes if you close the browser, same thing?
borzov
not sure what you mean by browser - if i close XnView browser then i effectively close the whole program, don't I?
BTW I think I jinxed it
Sometimes this happens after only 20 MB worth of images. It's very inconsistent
no you can open a view tab, and close the browserborzov wrote:not sure what you mean by browser - if i close XnView browser then i effectively close the whole program, don't I?
BTW I think I jinxed itSometimes this happens after only 20 MB worth of images. It's very inconsistent
quapurna
borzov, you can have images displayed in different tabs by doing this:
In Browse mode > Menu > View > Tab > Show (checked)
Thanks.
Thanks.
