Seems like you can rate images from 1-5 but I can't figure out how.
Also, what functionality is there for images after you've rated them? (aka, what's the point)
I feel dumb but can't figure out how to rate images
Vorpal Smilodon
- Forum Librarian
Re: I feel dumb but can't figure out how to rate images
Vorpal Smilodon wrote:Seems like you can rate images from 1-5 but I can't figure out how.
- Select one or more thumbnails.
- Open the View or context menu and go to Rating & Colour label.
- Apply a rating and/or color label to your image(s).
These settings can be customized by manually editing xnview.ini:XnView Wiki ([url=http://www.xnview.com/wiki/index.php?title=Browser_Mode_Shortcut_Keys]Browser Mode Shortcut Keys[/url]) wrote:Set rating: Ctrl+Numpad 1/2/3/4/5
Remove rating: Ctrl+Numpad 0
Set color label: Ctrl+Alt+Numpad 1/2/3/4/5
Remove color label: Ctrl+Alt+Numpad 0
XnView Wiki (UI-less Settings » [url=http://www.xnview.com/wiki/index.php/UI-less_Settings#Browser]Browser[/url] wrote:
- ColorLabel-# (0-4)
- Overrides the default color category names.
Value: String
- 0: Important
1: Work
2: Personal
3: To do
4: Later
- RatingLabel-# (0-4)
- Overrides the default rating category names.
Value: String
- 0: Bad
1: Below average
2: Average
3: Good
4: Excellent
View » Tree pane » Categories allows you to filter your images.Vorpal Smilodon wrote:Also, what functionality is there for images after you've rated them? (aka, what's the point)
Marunos
I had the same problem so thank U XnTriq
Vorpal Smilodon
