my Computer: 64 bit, Linux Mint 17.1 (Rebeca) with XFCE. XnViewMP is installed (newest Version). When I try to create a new Directory it
appears in the tree but it is not possible to work with. Also the info-line dont show the Dir. The same happens when I rename a existing Dir.
When I leave XnViewMP and start it again all Dir's are shown and you can work with. Maybe it's a bug in the database? Is there a ability to fix it?
[SOLVED] creating Dir's don't work
Re: creating Dir's don't work
I am very sorry - it's no bug. It was my mistake - I did something wrong. I set "filter" to pictures and saw no subdir's. So I tryed to rename, delete,
and move with the aktive dir. This can't work!! But now all is ok and the program works fine.
