Slide Show Reports Out of Memory
JRSofty
Post by JRSofty »
So I'm performing a slide show on a directory with over 10,000 pictures inside (split among multiple sub-directories). It seems to start and work but every once it will say that it is out of memory, and asks if I want to continue or cancel. If I continue it seems it might be skipping a photo, if I click back it again says it is out of memory and then will return to the last picture I see.
Is this something to do with the fitting of an image to the display window? The display window was set for 1200x800. This has been a problem for while now, I've just gotten around to mentioning the problem here.
I'm running XnView 2.25 on a Windows 7 (x64) computer.
Re: Slide Show Reports Out of Memory
only on a specific file?
JRSofty
Post by JRSofty »
It's happened a couple of times during a slide show so it could be several pictures from the same photoset. I can't be sure which since the file name is never displayed before the error appears.
Is there some way to activate a log for such errors?
