Program parameters needed
JStockton
Post by JStockton »
I often have need to open a file in XnView with another program (Opne With"), but when I do I need to add commandline parameters to the program's EXE. But I do not know if you can specify any such program parameters when you "Add Program." if you try, you get the eror message that says the program name is invalid.
Also, it would be handy to have file properties like current XnView filename, file path, extension, etc., passable so that sophisitcated commandline parameters can be built when adding a "Open With" program. I am often forced to use FastStone which has all these features when jumping to another program. I often time need to pass the filename to a macro program to perform multistep operations
It woud also be nice to jump to a program from not just a highlighted file, but also a highlighted folder.
Re: Program parameters needed
  1. Go to Info » About... to find the INI file location.
  2. Quit XnView.
  3. Open xnview.ini in a text editor.
  4. Go to the [OpenWith] section and add the entries.
  5. Save the changes.
  6. Restart XnView.
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=120705#p120705]XnView Shell Extension[/url]) wrote:
XnView Wiki (UI-less Settings » [url=http://www.xnview.com/wiki/index.php/UI-less_Settings#OpenWith]OpenWith[/url]) wrote:
  • Name_# (0-x)
    • Sets a custom name for the specified 'Open With' tool.
      Value: String
    Param_# (0-x)
    • Sets a custom command-line parameters for the specified 'Open With' tool.
      Value: String
      Note: The %1 placeholder in the string is replaced with the filename used to launch the 'Open With' tool.
    Working_# (0-x)
    • Sets a custom working directory for the specified 'Open With' tool.
      Value: String
JStockton
Post by JStockton »
Your solution does not work.
I added "/API TO /L1" for the ZTW (screen resizing parameters) , and now NOTHING happens in XnView.
At least before when there were no parameters, the ZTW program loaded.
Now nothing
I added %1 the the FSVIewer line--and then FastStone did nothing, so I took it out
This is very poor of XnView. For all ther many things it can do, this is a major disappointment!
[OpenWith]
OpenWith_0=C:\Program Files\Adobe\Photoshop Elements 9\PhotoshopElementsEditor.exe
OpenWith_1=D:\Alex\ztree\ZTW.EXE /API /TO /L1
OpenWith_2=C:\Program Files\IView\i_view32.exe
OpenWith_3=C:\Program Files\FastStone\FSViewer.exe
Name_1=ZTW
Param_1=/API /TO /L1
