Print margins are buggy...
kimi
Post by kimi »
Hi guys,
Admitted, i'm using quite old version of XnView, however printing is a feature which has been here for ages. So, i'm suspicous that seems to be a fixed bug in new versions.
Problem: When i set margins for a image before printing, the results aren't the same with what i set. For example; I set left and right margins both as 1 cm, whereas printed image has only 0.7 cm on the right, and the left margin is correct with 1 cm when i measure with my ruler.
Is this a known bug in XnView? Using Hp LaserJet 1102 with XnView 1.97.8.
Re: Print margins are buggy...
don't know if it was fixed, could you try lastest version?
