"Remove all metadata" option ? And faster images loading ?
Marebul
Post by Marebul »
Hi all,
Been using XnView for years !
XnViewMP seems to be a great evolution but still has some problems to me :
- Can't find the option in the Viewer to remove all metadata (In XnView, it's in "Edit > Metadata > Remove all metadata")
- Images loading is slower than in "Classic" XnView. Looks blurried for a tenth of a second before loading it completely. In XnView, it was immediate..
Can you help me to resolve these two issues ? While waiting, I'll stay on XnView Classic.
Re: "Remove all metadata" option ? And faster images loading
Welcome to the forum, Marebul (-:
Marebul wrote:Can't find the option in the Viewer to remove all metadata (In XnView, it's in "Edit > Metadata > Remove all metadata")
Tools » Metadata » Clean
Marebul wrote:Images loading is slower than in "Classic" XnView. Looks blurried for a tenth of a second before loading it completely. In XnView, it was immediate..
Blurred/LowRes images short time after opening image
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=97582#p97582]MP 0.38 Win: Very slow image display in fullscreen[/url]) wrote:
XnTriq wrote:Perhaps there should be some kind of threshold setting (“Don't use SIMD for pictures smaller than...”) like Use delayed high quality for pictures larger than (pixels) (browser only, also affects preview) in Tools » Options... » View » Fullscreen » Fullscreen.
You can adjust the minimum size in .ini with prevSize
Marebul
Post by Marebul »
Thanks a lot ! It works.
But could I suggest to have the same option for Metadata cleaning in the Viewer, like in Classic XnView ? Tools » Metadata » Clean menu is only in the Browser.
Meanwhile, this is enough to me to migrate on MP :D
