I shoot RAW (ORF) + JPEG and put the JPEG+ORF files into the same folders.
In XnView 2.x, I figured out a way to suppress the generation of thumbnails for the ORF files by adding ORF to the 2nd "Custom Files" list, with thumbnails disabled and preview enabled.
That works fine, but I can't figure out how to do something similar in XnViewMP.
Motivations, etc.:
a. I want both files listed so I can delete both if I don't like an image, or move them, rate them, etc.
b. however, no point in reading/generating/caching the thumbnails for both as they are the same... it's faster and easier to only have the thumb on the JPEG.
Thanks!
Suppress thumbnails for RAW (ORF) files
Re: Suppress thumbnails for RAW (ORF) files
you have the same setting in "File List>Custom Filter"
bobbozzo
The Custom Filter settings page appears slightly different in MP.
In fact, the whole filtering system seems to work differently; for example, if I choose to filter 'All', the Custom filter seems to be applied.
Right now, if I put ORF in the Exclude, it filters them out on 'All' and 'Custom', which is OK for that view.
But, I cannot find a way to show ORFs in the list without thumbnails, which does work in non-MP -- I believe that's I put ORF in 'Custom Files' in non-MP.
How can I do the same in MP?
Thanks!
Thanks!
oh ok i understand in MP the exclude/include is applied in all view mode
