debug log
bitz4
debug log
Post by bitz4 »
Is there a way/option to generate a debug log?
MP 0.90 x64, Win 7 64-bit
Re: debug log
bitz4 wrote:Is there a way/option to generate a debug log?
which problem?
bitz4
Re: debug log
Post by bitz4 »
Sometimes I open a pic and it just closes. No message or anything. It's inconsistent in its behaviour.
Re: debug log
bitz4 wrote:Sometimes I open a pic and it just closes. No message or anything. It's inconsistent in its behaviour.
and you have not a crash dialog to send report?
bitz4
Re: debug log
Post by bitz4 »
No. That's what "No message or anything" means. :)
Re: debug log
m.Th. ([url=http://newsgroup.xnview.com/viewtopic.php?p=122001#p122001]Crash when new file appears in directory[/url]) wrote:
slarti76 wrote: If there's any directory where I can look for logs, I'll gladly send them to you.
The dump files (aka. crash logs) are on Windows in the user's temp directory.
Assuming that your Windows drive is C: and your user name is 'foo' then the directory would be:
C:\Users\foo\AppData\Local\Temp
Go there and you'll see some files like this:
c1a8215b-31b8-4b89-af43-b2687e3bc03b.dmp (a big "code" (ok, hash) in front and the .dmp extension)
take all these files, zip them and send them to Pierre.
bitz4
Re: debug log
Post by bitz4 »
Alright, I've found an images which consistently closes XnViewMP. Obtained the dump and attached it.
Re: debug log
bitz4 wrote:Alright, I've found an images which consistently closes XnViewMP. Obtained the dump and attached it.
is it possible to send me the jpeg images?
bitz4
Re: debug log
Post by bitz4 »
sorry for that... not at the time because I removed the files in question
I often have crashes, I managed to capture this one with image file.
side note: the kcrashreporter should allow to upload image as well.
