How to Use XView
virag
How to Use XView
Post by virag »
I Can't able to open .vff File in my laptop , i have locked my personal folder with Verify Face Recolonization Software in Lenovo , i have download this software but can't able to use i need Step to convert this vff extension file to normal folder..tell me the procedure.
Send me the details on my mail Id : <-- removed* -->
Regards
Virag Nirmalkar
Re: How to Use XView
The filename extension .vff is associated with more than one file format. Sun TAAC images (Visualization File Format) are supported by XnView, but you're dealing with a VFF file that has been encrypted by a face-recognition software called VeriFace. XnView cannot decrypt this type of file.
