Hello!!
Great application. The speed it renders thumbnails is totally WOW!!
I have one request though: I like pasting animated gifs in my e-mails. While I am able to copy animated gifs using "copy as image data", pasting them in the body of the messege stops them from animating, thus pasting only the first frame of the gif.
Can this be fixed in the next release?
Thank you,
Baruch Richter
Israel
http://www.artlab.co.il
Pasting images as "image data" should paste animat
Re: Pasting images as "image data" should paste an
Not sure that i can make that, because the clipboard has only BMP formatBaruch wrote:Great application. The speed it renders thumbnails is totally WOW!!
Baruch
I used to do it with ACDSee 4.0
I used to do it with ACDSee 4.0, so I guess it is possible.
Look at it as a challenge if you'd like
Bye
Good luck
Bye
Good luck
