Click on header directly to sort
tylenolthumb
Post by tylenolthumb »
I think it'll be very easy for user to click on the header directly to sort files, instead of clicking the sort button (the green button with up and down arrows) and then select.
Re: Click on header directly to sort
but you can already click on it
tylenolthumb
xnview wrote:but you can already click on it
I mean left click click on the column names directly on the header.
For example, if I want to sort it by size, it would be great if I can just left click on size (red circle) to sort everything.
Right now, I have to click on the sort button (green circle) or right-click header and then select to sort.
It would be great to have this feature, just one click to sort. And also click again to sort it from ascending to descending.
on windows?? If i left click on the column header the sort is made
tylenolthumb
really? Mine doesn't do anything. Are you talking about the area of the red circle? Because I can't click that.
yes
tylenolthumb
Are you clicking the header bar itself? I can't do it. Am I doing something wrong?
edit: My brother's computer can do it, so I think it's my computer. I don't know what's going on.
edit 2: okay I reinstalled and it seems to work!
