Folder Rename in Folder Tree Panel
Ника
Post by Ника »
In the folder tree panel, if you want to rename a folder, you should right-click it, then choose rename. Right?
No. You have to SELECT it first, and then right-click it, and then choose rename.
This is not a bug, but do you agree that it has one step that we can live without?
I am not that lazy, but I simply don't have the habit to pre-select it, because in most programs right-click also do the selection by default.
It would be nice if the current behavior could change so one could right-click any folder in the folder panel and just choose "rename"
Thank you in advance for considering this suggestion,
Nika
p.s. - Sorry if this is already covered, but I have tried to search for the similar tread, but the "folder" and "rename" are too common words and the first 50-60 treads i took a look didn't address this issue.
