Numeric Keypad doesn't work for Colour Labels
bobbozzo
Post by bobbozzo »
Hi, on Windows with XnView MP 0.72 x64, I can use CTRL-# on the Numeric Keypad of my keyboard to assign a rating, but CTRL-SHIFT-# does not work on the numeric keypad (it does work on the top row numeric keys).
XnView classic works fine with the numeric keypad.
Thanks!
bobbozzo
Re: Numeric Keypad doesn't work for Colour Labels
Post by bobbozzo »
Also, CTRL-SHIFT-0 does nothing, even using the numeric keys at the top of the keyboard. (1-5 do work)
Thanks
you can change the shortcut
bobbozzo
Post by bobbozzo »
OK... CTRL-SHIFT-~ works.
Thanks!
