Can't play mp3 files.
frankest
Post by frankest »
I created a slide show with an mp3 file as background music.
However, the sound is not playing. I thought it might be an
inssue with variable or constant bit rates but it doesn't help
so much. Some mp3 files played back others not.
Re: Can't play mp3 files.
none of your mp3 can be played in slideshow? And in xnview?
frankest
Post by frankest »
Slideshow or xnview makes no difference. Some mp3 files can be played some not.
I converted some mp3 files from variable bitrate to constant bitrate but nothing changed.
In MediaMonkey all the mp3 files can be played of course.
It seems that you have no mp3 (DirectX) codec
frankest
Post by frankest »
Updated directx on my computer and installed ffdshow,
but didn't help (Windows 8.1).
Please try to install klite codec pack?
frankest
Post by frankest »
Great, that works!
