[2.31] 'Recognize by extension..' for user plugins
Arty
Post by Arty »
Hi, Pierre.
Disabling "Recognize only by extension" option doesn't work for user plugins in XnView v2.31. Could you please enable using it for user plugins? I have my own plugin for PVR files and sometimes I need to view them with different extension but I can't.
Thanks!
Re: [2.31] 'Recognize by extension..' for user plugins
new bug??
could you send me a sample file and the plugin?
Arty
Post by Arty »
Plugin is here: http://newsgroup.xnview.com/viewtopic.php?f=35&t=27877
You can get sample pvr file from plugin archive in "test" folder. To reproduce bug: change test file extension for example from .pvr to .bytes
P.S. I think it's an old bug. Previous versions did not work as well.
Arty wrote:Plugin is here: http://newsgroup.xnview.com/viewtopic.php?f=35&t=27877
yes xnview use always extension for user plugin.
could you rebuild the plugin, and modify extension for "pvr;*"?
Arty
Post by Arty »
I've already try this. But it looks like XnView get plugin supported extension from plugin dll name! It don't use information from gfpGetPluginInfo().
Arty wrote:I've already try this. But it looks like XnView get plugin supported extension from plugin dll name! It don't use information from gfpGetPluginInfo().
please send me it?
Arty
Post by Arty »
Here is it https://dl.dropboxusercontent.com/u/37559409/xpvr.usr
It return "pvr;*" in extension parameter for gfpGetPluginInfo()
ok, will be added in next version
