"Watch for new images" not working with multiple subfolders
yeti5
Post by yeti5 »
The feature "Watch for new images" in the Slide Show Options is exactly what I was looking for, but for me it only works if there are images in a single folder.
If I use a folder with images in different subfolders then the slide show will not update if i add images in any of the subfolders.
Would be great if that would work anytime in the future, because i'd really need that future at my wedding in 3 month :)
Best regards
yeti5
Re: "Watch for new images" not working with multiple subfold
and it's not possible to add subfolders too?
JohnFredC
Post by JohnFredC »
Support+
In the situation where digital camera images download into separate folders by date, a user might wish to select the parent folder and have the slide show automatically incorporate images from new subfolders as they appear.
There are other examples, too.
John
