Thumbnail cache database: use WebP compression
wOxxOm
Post by wOxxOm »
It's well known that WebP provides a much better quality/size ratio along with alpha mask support, so using it for the cache-db could provide two advantages - smaller size and/or better quality. And lossy low-quality compression can still store the alpha channel, which can used when drawing the thumbnails.
I think it should be selected by default in thumbnail cache options, even without ZIP/JPG (although these should be internally supported for old cache-db files).
  • WebP lossy - low quality
  • WebP lossy - medium quality
  • WebP lossy - high quality
  • WebP lossless
  • None
oops66
Re: Thumbnail cache database: use WebP compression
Post by oops66 »
Catalog:
Enable thumbnail caching
Lossy - High quality (WebP) v (as default)
