icui18n problem. Can not start application. Ubuntu
rotozeev
Post by rotozeev »
Hi!
Yesterday I had updated my ubuntu system. After this xnconvert dont work! If I run it though terminal I see this error message:
Unable to load library icui18n "Cannot load library icui18n: (icui18n: cannot open shared object file: No such file or directory)"
ThumbLoaderThread :: stop()
### ThumbLoaderThread :: stop() ok
QCursor: Cannot create bitmap cursor; invalid bitmap(s)
QSettings::endGroup: No matching beginGroup()
Segmentation fault
Reinstall of xnconvert didnt help. Help me please.
Re: icui18n problem. Can not start application. Ubuntu
which version of ubuntu do you have?
rotozeev
Post by rotozeev »
xnview wrote:which version of ubuntu do you have?
14.10 Linux Mint.
14.10 Linux Mint.
do you have a way to install the missing library?
rotozeev
Post by rotozeev »
The problem is strange. I have a logical disk on HDD where I saved scripts for xnconvert. And xnconvert didn't run when this logical disk was mounted. But when I try to run xnconvert in case of unmount that disk - it successful run! After this it is starts.
