EXIF: LensMake, LensModel and LensInfo
Schwinni
Post by Schwinni »
Hi all together,
is there a way to display information about the lens in XnViewMP?
The values exist in my files and are displayed by ExifTool, e.g.:
Exif:LensMake=FUJIFILM
Exif:LensModel=XF55-200mmF3.5-4.8 R LM OIS
Exif:LensInfo=55-200mm f/3.5-4.8
I have tried to use
{EXIF:LensModel}
{EXIF:Lens Model}
{EXIF:xa434}
But all three notations are displayed literally.
What can I do to display the lens tags?
Best regards
Chris
P.S.: The tag ids are listed here: http://www.sno.phy.queensu.ca/~phil/exi ... /EXIF.html
Re: EXIF: LensMake, LensModel and LensInfo
please post a sample file
Schwinni
Post by Schwinni »
I attached an image which I resized with XnViewMP.
The metadata was preserved.
You will see that data about the lens is contained:
Lens Info: 55-200mm f/3.5-4.8
Lens Make: FUJIFILM
Lens Model: XF55-200mmF3.5-4.8 R LM OIS
Lens Serial Number: 47A03498
Best regards
Chris
currently only nikon and canon lens id are supported... i'll check for fujifilm
Schwinni
Post by Schwinni »
Hi Pierre,
thanks for looking into this.
Be aware that the 4 above mentioned fields are standard tags from Exif Version 2.3: http://www.sno.phy.queensu.ca/~phil/exi ... /EXIF.html
Of course FujiFilm also uses own tags, but these contain other information: http://www.sno.phy.queensu.ca/~phil/exi ... iFilm.html
Best regards
Chris
Schwinni
Post by Schwinni »
Hi Pierre,
any news regarding the lens info?
hairlesshobo
Post by hairlesshobo »
I would also love to be able to add the LensModel tag to the info panel. I use several manual lenses that I have to manually add this information to and it can be very tedious to have to use a different application just to check if I remembered to add the lens info. Any plans to add this tag to info?
Thanks in advance!
Bezier
Post by Bezier »
An old thread, but apparently still the same situation.
I also desperately need access to the lens information, both for displaying it and, even more importantly, for searching/filtering for it. No complicated decoding of manufacturers' secret information needed, just access to the {EXIF: Lens Model} tag in all the places where there is already access to other EXIF tags. Seems like a minor change with major benefits to me ;-)
Best regards,
Bezier
